Dawg68
Nitrous
I’m in the process of replacing all fluids on my Roadster. The other day I was bleeding my front brakes and while doing so I noticed that my coolant reservoir was empty. I took off the cap to the radiator and it was full. I also noticed a little drip under the water pump. Not a leak but just a drip. I cleaned everything up and placed a piece of cardboard under the pump to make it easier to identify any potential problem. While doing the oil change and running the bike I noticed another drip on the cardboard. While the bike was running I checked the weeping hole and it was a little damp but as the bike ran the dampness dried out and there were no more drips and things are still dry. I ran the bike till the fan cycled and the reservoir filled back up to the min line.
The next thing I want to do is flush the coolant and replace. Any ideas why to pump would drip a couple of drops...no more than a half a teaspoon if I was guessing. The bike has been sitting since August. I start and run it every couple of weeks. I know if fluid starts comming out the weeping hole the pump could be failing but the bike only has 34K km.could sitting cause seals to go? Or is it normal for the odd drip to come out of the weeping hole?
Thanks for any advice
