kblahetka
Last year the water cover gasket started leaking so I replaced it and changed the coolant. It was fine after until this spring I fire her up and once running I saw leaking so I thought it was the same gasket. I replaced and still leaking when running. Upon closer inspection it looks like its coming from behind than gasket, either from where the water pump goes into the case or I can't tell if there's a pressure hole there by design. I only had a brief chance to look.
So the question is, one to remove the pump I just undo the 2 bottom bolts and slide it out? Is there any more to this? Is it likely its leaking from the O ring on the back of the pump? For those of who who have had this off, is it just a rubber or brass ring? Any thing I need to know about replacing that?
