AFTER WORKING IN THE BIKE THESE DAYS I HAVE NOTICED THE ALUMINUM PARTS IE WATER PUMP HOUSING SHOWING SIGNS OF CORROSION , ANY THOUGHTS ON A WATER LESS COOLANT SUCH AS EVANS BRAND , PROS AND CONS
I use the Evans coolant in hotrod MX engines and it is great for knocking off temp. One needs to clean the system first or put it straight in a new engine. If you want to put it in your Rocket,the only negative I can see is cost.It is good stuff.
