Anyone found the voltage regulator? Wonder if there is room to replace it with the SH847 type regulator? Swapping it might allow for longer stator life.
Voltage regulator tested bad, replaced, still no charge. New full battery, the service manual tells how to check ACV output which proved to be in spec, BUT.., a grounded stator will show good ACV output until loaded. As soon as you are connected and running you are loading the stator. Thus dim...
That is another thought. If it breaks under warranty let them fix it. If it concerns you buy a new regulator and have it ready to go when the warranty expires.
O.K. that is an old thread but some great info.
How many made the switch and what were the results?
It would seem Triumph is still using the shunt type, anyone know why?
