Waconut
.060 Over
I know some of you are using these. I'm mounting some on my roadster and the question I have is did you use the 8mm bolts that came with them on the front or did you bore out the mounting piece and get a 10mm bolt. If you used the 8mm, have you had any problem with the fender shifting? Id rather use a 10mm as thats what the front factory bolt is, but having trouble finding one the proper length and pitch. Seems nobody carries a 10mm in 1.25 thread unless its short. Any info would help. leaving on a run in two weeks and would be nice to have the bags on.
