nolton
The wire diagram shows several accessory connections. Fuel gauge, Heated grips, Clock, accessory lights and socket.
Which of these connections are not powered by the key switch and which connections could cause other problems if used other than their intended use? Example: connecting to the fuel gauge accessory plug could cause problems seeing that it is connected to the engine management relay and the fuel pump relay.
Where could I find the mate harness for these connections without having to by the accessory?
