Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,857
- Location
- Ride
Cool
Electric
TECH SPECS
POWER TRAIN
Electric
TECH SPECS
POWER TRAIN
- Motor: Z-Force® 75-7 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor
- Max Output (hp): 60hp (45kW) @5,300rpm
- Max Torque (ft-lbs): 81 ft-lbs (110 Nm)
- Batteries as tested: ZF13.0 powerpack, ZF6.5 powerpack (combined peak power 19.5kWh)
- Charging System: 1.3kW on-board charger from a standard 115V/15A breaker (estimated 13 hours to charge from empty to 95%)
- Range as Tested: Up to 165 km
- Recommended Max Cruising Speed: 105 kmh
- Maximum Speed as Tested: 140 kmh
- Overall Length: 233 cm
- Overall Height: 137 cm
- Overall Width: 162 cm
- Seat Height: 79 cm
- Ground Clearance: 23.4 cm
- Max Permissible Weight: 600 kg
- Dry Weight: 373 kg
