RomeoTango
Standard Bore
2008 Rocket III Classic. Replaced the starter motor (just the motor) with one from the recommended Toyota. Made 4ga battery cables and swapped at the same time.
Now bike will not start. Has power and lights up, but engine light is on.
Went back over all my connections. Did not actually disconnect anything but battery and starter.
Only item I realize was not "right" was the auxiliary connectors on the battery cables. The female connectors I purchased fit, but the security/snap portion was too long to maintain a secure catch on the male side. I sorta jury-rigged the original cables back to the battery and used the original auxiliary connectors. Still nothing.
Thinking I should put the original battery cables back on, and check again.
Could there be an issue with the starter?
Would much appreciate any advice.
