Fenners
Hello everyone,
Just bought a RamAir kit which I will fit once it arrives. I have a Campbell 1 in to 6 exhaust system fitted to the stock header (3 cans either side with a cat delete).
Ok here is my current situation. I bought the Lonelec cable and thought play safe and save the current map. Then tweak the RPM and top speed and copy the I3 maps to open the 1st, 2nd and 3rd gear settings. I was still unclear if setting the secondary's to 100% would give me any benefit, so intended to hold fire on these until after seeing the results of the above?
In my case everything stalled at the first hurdle. the Lonelec cable seemed to connect ok and I got the flashing green light - however when I tried to read the ECU map I got a warning - Unknown Map type. The number is given as 20093.
When I visited my local Triumph dealer recently they indicated that the Bike requires 2 recalls; one for the fuel filler cap seal and the other for an Idle problem.
I am thinking that the recall for the idle may lead to a new map being loaded possibly 20227 or 20228. Therefore I may need to wait and see what happens after the recall before changing anything.
Has anyone else had the same problem of having an unknown map type? Can I load a new map over the top of this?
Does anyone have a map that I could use after fitting the RamAir?
My rocket is a 2006 Classic.
