Probably not as most prefer radials over bias they do make a 140/75/17 V rated radial. I'll have to put it on my list of tires to try since they also have a 240/40/18 to match.
Pirrelli and metzler are the same company and both tires kind of suck. Michelin commander II is what I run on the Harley. Actually the Michelin Scorcher was designed to be run on the V-Rod. Standard tire for the late model V-Rods. Now sold as standard equipment on various models of Harley's. Running a Scorcher II 140 on the Rocket and Bridgestone rear. Second set and love it.
Sorry I did not realise you were down under so I'm not sure if you can get the battle criuse down under. Its just a thought as its not often we can at least run front and back from the same manufacturer. Look at the tread my bet is it will replace the exedra line. Maybe we will see a 240/55/16 battle criuse in the end
