Another TuneEcu virgin in need of some advice.
I have ordered my OBDII cable and look forward to using tuneecu. I have been doing tons of research on this and I need to make a good decision.
First of all, The only performance mod that I have is a custom made straight through, full exhaust system (no cat of course). Just fitted a new stock air filter.
I have disconnected the O2 sensor which has clearly made the bike less snatchy at low revs and smoother down low aswell.
I was looking at the OEM map options and thought that 20228 would be good, but not 100% sure. Then I saw loads of custom maps and secondaries 100% open which I'm not sure about either. After disconnecting the O2 sensor, decel pop reduced a bit. My idle is low at start up (around 650-700) and gets to about 950 when heat soaked.
Should I just use OEM 20228 or can anyone suggest a better option that's worked for them. I just want the best possible tune for my exhaust.
Would it also be better to turn off the SAI sensor?
I hope I haven't confused the situation, any help will be appreciated, Ben.
