DEcosse
If it's no Scottish it's CRAP!
Have a question about using the Android version for Tuning - I'm more used to the Windows program
With Windows, when doing a run you can just use the Map Edit screen and can see the Throttle Position highlighted across the top axis to give you a direct readout of actual Throttle Position
i.e. you want to do a pull at 50% - you can use the map edit screen as a 'live' throttle position indicator to hold the throttle with the 50% on the axis highlighted.
This function doesn't appear to be present in Android? (i,e, no highlight on the TPS axis)
Where do you view Throttle Position when doing a pull in Android? (in the dashboard or sensors screen these don't display actual throttle position but % of the applied voltage)
(this is a lot more noticeable with older models where the TPS indication in sensors and dashboard might only be 70% when the actual throttle is 100% wide open)
So - you tuners out there - where are looking on ANDROID version to get ACTUAL TPS position??
