TuneECU and Dyno in Las Vegas, NV
Discussion in 'TuneECU Source' started by JSHRAM, Aug 11, 2018.
  1. JSHRAM
    JSHRAM .040 Over
    Country:
    United States
    98
    Featured Threads:
    16
    Media:
    10
    185
    43
    Cedar City, UT
    Ride:
    2011 Triumph Rocket 3 Roadster
    Hooray! I have been going to this shop for several years and always loved the professional expertise there. Dale, the owner, agreed to help with my Tune ECU. So, here's how it went. He ran the bike on my chosen map and tracked where it was running lean/rich. Then I saved that map file with a new name on MY computer and he tweaked it right on my computer, I then saved the file, and downloaded it to the bike, and he'd run it again.. we did that about 4-5 times.
    So, until he figures out TUNE ECU and gets it into his dyno computer (he's very protective about his Dyno computer for good reason) you'll have to bring you own lap-top and your own cable..
    Racers Edge Performance | Motorcycle Performance Shop, 1-On-1 Training and Private Track Day Events
    But the GREAT news, is that Dale will help us Tune ECU folks in the US South-West! WOOT!
    Dale, at Racer's Edge. (702) 257-3808
  2. JSHRAM
    JSHRAM .040 Over
    Country:
    United States
    98
    Featured Threads:
    16
    Media:
    10
    185
    43
    Cedar City, UT
    Ride:
    I figure the more folks that ask to use Tune ECU, the more motivated he'll be to get it working on his computer, so go on in! Price was right too.. he charged me $100 for the session.... I just had to be patient as he did business in-between runs. .no problem. Glad to be patient for such great service. Besides, he was patient when I was fiddling with my computer/program. Best to make sure you're up and running with that before you go in....
    BillyIndiana and Paul Bryant like this.
  3. BigNorm
    BigNorm Boobie Inspector
    Country:
    United States
    3,033
    Featured Threads:
    24
    3,632
    823
    Minden, NV, USA
    Ride:
    2014 Rocket 3 Touring
    Good news. Vegas is only 7 hours from me. How does your bike run after the tune?
  4. JSHRAM
    JSHRAM .040 Over
    Country:
    United States
    98
    Featured Threads:
    16
    Media:
    10
    185
    43
    Cedar City, UT
    Ride:
    Fantastic! Much smoother, easier transitions through throttle and no decell popping anymore.. plus it isn't lean! yesterday I did 650 miles around through Page, AZ and the North Rim of the Grand Canyon... zero issues... burns a little more gas now, but that's how to not make it lean...
    Jvheli, BigNorm, Steel and 1 other person like this.
  5. 1olbull
    1olbull Riding Motor Since 1950
    Country:
    United States
    19,417
    Featured Threads:
    101
    Media:
    5
    14,622
    823
    Tacoma, WA
    Ride:
    2012 R3R - 1980 Honda Twinstar - 2018 Yamaha XT250
    Please post your dyno for us to see.
  6. JSHRAM
    JSHRAM .040 Over
    Country:
    United States
    98
    Featured Threads:
    16
    Media:
    10
    185
    43
    Cedar City, UT
    Ride:
    [​IMG]
    Jvheli likes this.
  7. Jvheli
    Jvheli Supercharged
    Country:
    United States
    410
    Featured Threads:
    11
    560
    103
    Milwaukee, Wisconsin
    Ride:
    2016 Rocket Roadster
    Awesome! Sounds exactly like my experience! Enjoy!
  8. DEcosse
    DEcosse If it's no Scottish it's CRAP!
    1,625
    Featured Threads:
    22
    Media:
    19
    2,015
    323
    Bay Area, CA
    Ride:
    Triumph Daytona (Custom)
    These observations appear critical but they are intended constructively and not argumentatively
    So the plot is a wide-open throttle (max HP) plot
    A/F is right at 14 (pretty much exactly - flat line) up to 80mph (rpm would have been more useful) which almost suggests it was in closed loop control over that part of the curve (but then again it can't be if it was WOT);
    then from 80 + it certainly does look lean - at least where making power is concerned.
    You mentioned it was smoother through the rpm range but that you only did about 4-5 iterations
    Honestly, that is nowhere nearly adequate to dial in the whole map - maybe just the wide-open throttle map - and the $100 is indicative of that (and a more than fair price for a WOT tune)
    But that is not going to do much for your mid-range performance (although maybe that's more the area he was focusing on?)
    To do a thorough tune, you really need a pull at each throttle opening increment - that is 12 pulls for base reading alone and only considering the 10% to 100% throttle range (which is in essence just half the map!)
    Even if every other throttle increment and interpolating in between, that is still 6 pulls for baseline alone
    And not even touching the idle/off-idle control (below 10%)
    Again, I'm not trying to pick holes in your experience and you are clearly happier with the post-tune performance, so that is what matters
    Did you get any other plots for throttle openings other than 100%?
    BigNorm likes this.
  9. Claviger
    Claviger HP Junkie extraordinaire
    5,111
    Featured Threads:
    118
    Media:
    69
    6,342
    823
    Olympia Washington
    Ride:
    '14 R3R, '02 Daytona 955i
    @JSHRAM glad to hear you found a tuner in Vegas that’s willing to work with TuneECU.
    150 on an SAE chart, not bad at all, though it is a big correction factor, so not ideal weather!
    There’s a little room for improvement that will help tame the heat from your headers, if the chart is the tune you rode away with.
    Wish he’d given you some part throttle print outs.
    Ideally, you want the AFR to track on or close to the red dashed line, usually within a half an AFR point will yield good safe results. In particular from 4000-5200 you can add 10% and pull it down out of the 15:1 AFR range. It may not make any more power, but knowing first hand how hot it gets where you live, it will ensure a good 115f day doesn’t cost you a motor :)
    I see the sheet notes say he added fuel in the 0-15% range, how is the slow speed throttle response now, like below 2000?
    BigNorm likes this.
  10. rng3
    rng3 "There is no replacement for displacement"
    382
    Featured Threads:
    3
    301
    73
    Chester county, West of Philadelpha
    Ride:
    Rocket 3 roadster 2017
    Curious what mods you have made to the bike, air cleaner, exhaust, etc.
    Rick
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
