Justin Lakes
.040 Over
I've been fighting with the hydraulic clutch on this since the build... with leaks due to bad O-Rings and such, but one issue that hasn't went away is under Hard acceleration the clutch lever becomes limp. You can actually feel the lever begin to collapse under full throttle , you can then give the lever a few squeezes and feel pressure build back up and you're okay as long as you just cruise. ... I've experienced something similar in drag racing at the track with a particular type of car (4th Gen fbodys) and it's known as "dead pedal". Basically at the end of the track there's no clutch pedal left and you have to pump it back up a few times to regain pedal feel/ pressure.
Does anyone have a clue as to what's going on ?
