There is a little technique involved in putting a Rocket in 1st. If you wait to long after pulling in the lever, the gear cluster will stop. If the first gear dogs aren't lighned up, it won't want to go into gear. I've taught myself to hit the shift lever at the same time the clutch lever contacts the handlebar, you then get a bit of a clunk, and know the gears are fully engaged.
