Power-Tripp
Turbocharged
Here is an interesting comparison of exhausts on the same Rocket:
Same 2007 Rocket III classic (2 weeks apart) with TORS and tuning, and again with Jardines and tuning.
In all runs, 89 octane Shell fuel was used, and individual K&N filters (under stock BearClaw). The Jardines were hand ported at the head flanges, and in the collector, then ceramic coated (to reduce heat on the rider's leg).
Yellow - TORS with downloaded tune.
Purple - TORS with tuning (TuneBoy).
Green - Jardines with downloaded tune.
Red - Jardines with Tuning (TuneBoy). 3000 rpm really responded well to additional fuel and ignition advance. Part throttle and transient response improved even more.
For comparison, a stock R3 usually puts up 106-108 hp on my dyno.
I think the K&N's under the stock (un-cut) BearClaw are at their limit here. A heat block (from the radiator and engine heat) and cutting or removing the bearclaw to install larger filters should allow a bit more. But this is a nice gain with such simple modifications, IMHO.
