Mark Graham
.040 Over
- Joined
- Jun 3, 2015
- Messages
- 63
- Location
- Bondurant, Iowa USA
- Ride
- 20 Triumph Rocket GT. 20 Kawasaki Z H2. 16 KTM
These have been one of the most valuable purchases for a long time. I took the bike in to the shop and was called over to be asked if I ever check my pressure. The tire was running low on air. I don't check the pressure as much as I need to. I figured I would give the Tire Gard a try. These things work excellent. Once the wireless unit is turned on all you have to do is roll the bike forward and you will get the current pressure reading in the front and rear tire. You set the upper and lower limits of both tires and it gives you and audible signal if you have too much or not enough pressure.
I ended up buying another one for my 2nd bike.
