Tips on Filling your Vehicles
JC Rocket Rider
Standard Bore
Tamworth, Australia
This is a Message received from a friend:
ONLY BUY OR FILL UP YOUR CAR OR BIKE IN THE EARLY MORNING WHEN THE GROUND TEMPERATURE IS STILL COLD.
Remember that all service stations have their storage tanks buried below ground. The colder the ground, the denser the fuel, when it gets warmer petrol expands, so buying in the afternoon or in the evening.... your litre is not exactly a litre.
In the petroleum business, the specific gravity and the temperature of the petrol, diesel and jet fuel, ethanol and other petroleum products play an important role. A 1degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
WHEN YOU'RE FILLING UP, DO NOT SQUEEZE THE TRIGGER OF THE NOZZLE TO A FAST MODE.
If you look, you will see that the trigger has three (3) stages: low, middle, and high. In slow mode, you should be pumping on low speed, thereby minimizing the vapours that are created, while you are pumping. All hoses at the pump have a vapour return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapour.|
Those vapours are being sucked up and back into the underground storage tank so you're getting less worth for your money.
ONE OF THE MOST IMPORTANT TIPS IS TO FILL UP WHEN YOUR TANK IS HALF FULL.
The reason for this is, the more fuel you have in your tank, the less air occupying its empty space. Petrol evaporates faster than you can imagine. Petroleum storage tanks have an internal floating roof. This roof serves as zero clearance between the petrol and the atmosphere, so it minimizes the evaporation.
Unlike service stations, here where I work, every truck that we load is temperature compensated, so that every litre is actually the exact amount.|
ANOTHER REMINDER, IF THERE IS A FUEL TRUCK PUMPING INTO THE STORAGE TANKS, WHEN YOU STOP TO BUY, DO NOT FILL UP - most likely the petrol/diesel is being stirred up as the fuel is being delivered, and you might pick up some of the dirt that normally settles on the bottom.
Hope, this will help you get the maximum value for your money. :D :D
Should you be filling the tank to the brim [cars etc] as 1 lt = approx 1 kg.
So aren't you using up extra fuel just to carry all that extra weight around...?
That is true, especially for big tanks like my 4x4 Expedition (30 gallon tank, which under "Military Power" mode (evacuating SFL) can take 33-35 gallons up the tube).
1 Gallon weighs about 6 pounds. So anything over half a tank, I'm carrying around a 90 pound blond who isn't there :p
I've found a website that shows local prices, and a map. I generally try to find the cheapest gas station, and try to plan my fill up along my daily route. I fill up b/c I don't want to spend more time short on gas in expesnive zones. When I do, I just usually get two gallons, reset my range and estimate to the nearest cheapo gas sight.
FWIW TOP TIER Gasoline Retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
