Throttlebody Mods and Tune
Discussion in 'Rocket Performance' started by Claviger, Sep 13, 2018.
Tags:
  1. Claviger
    Claviger HP Junkie extraordinaire
    5,192
    Featured Threads:
    122
    Media:
    69
    6,645
    823
    Olympia Washington
    Ride:
    '14 R3R, '02 Daytona 955i
    Well well, Alain came through because he’s amazing and disabled codes p0222 and p0638, the two codes that come up when you remove the secondary stepper and tps respectively. Tested and ridden today, no codes came up.
    So, now, if one were so inclined one could unbolt all the secondary hardware, fill the shaft holes with appropriate material and have nice clean shots down the TB. No need to bore them to clean up air flow for the built motor guys.
    Please PAY ATTENTION to the tables and rev limiter!!!
    MAP:
    https://www.r3owners.net/resources/my-tune-read-the-description.28/download?version=28
    Throttle Bodies after being returned, he gained 3mm in diameter without too much issue.
    The little port where you can see light coming through is normally sealed on the stock TBs. After cutting, you can now see it is no longer sealed. These ports I sealed with more JB Weld Marine, leaving a little blob outside so they're "mushroom" shaped plugs with little/no change of dislodging and going into the motor.
    It turns out George at Maxbore adjusted the blades to seal so well I had to close the gap on the TPS calibration from 0.6 and 0.72 to 0.62 and 0.70 volts. If not, it allows too much air to pass and does a surging idle, 900-2000, 900-2000 cycle thing.
    Here you can see the before and after of blending the TBs into the mounting rubbers to the head:
    4D3DF1CA-9475-477E-A28B-EFC59288A421.jpeg 4949299A-0B7E-4502-8044-E955E24EE6F6.jpeg
    geno, Nat67, bigprop and 8 others like this.
  2. Claviger
    5,192
    Featured Threads:
    122
    Media:
    69
    6,645
    823
    Olympia Washington
    Ride:
    Should anyone else modify their TBs do be warned you’ll need to play with ISCV values, 0.6 and 0.72 no longer work.
    Currently working out what’s best for my setup, but, each bike will be different, you’ll need to reduce the 0.12 delta value by some amount depending on the system as a whole or it’ll stall while rolling if you pull the clutch or go to neutral.
    Nat67 and bigprop like this.
  3. Navigator
    Navigator Top Fuel
    Country:
    United States
    1,724
    Featured Threads:
    18
    2,523
    323
    Banner, WA
    Ride:
    2009 Rocket Touring
    I have no understanding what Rob just posted. :(
    bigprop likes this.
  4. 1olbull
    1olbull Riding Motor Since 1950
    Country:
    United States
    20,297
    Featured Threads:
    108
    Media:
    5
    15,999
    823
    Tacoma, WA
    Ride:
    2012 R3R "Kong" - 2011 R3R "YurMama"
    bigprop likes this.
  5. scot in exile
    scot in exile Living Legend
    Country:
    United States
    7,909
    Featured Threads:
    180
    9,525
    823
    Fort walton Beach FL, Glenrothes Fife
    Ride:
    2005std, 2011 Carp Roadster, 2001 Tri Adventurer,
    Mike let me explain it to you in easy to understand English,
    the thingymajig will not work with the old thingymajig, then stuff something in a shaft, blow the motor until you are red in the cheeks then have Rob check your work. Hope that clears up all the confusion
    Gregger, BigNorm, Nat67 and 4 others like this.
  6. warp9.9
    warp9.9 Pocałuj mnie w dupę
    8,537
    Featured Threads:
    9
    Media:
    14
    10,136
    823
    Forest City Illinois
    Ride:
    07 Rocket
    Its probably because he added a whatsamacallit and a doomahickie :D
    Gregger, BigNorm, Nat67 and 2 others like this.
  7. Neville Lush
    Neville Lush www.nevillelushracing.com
    Country:
    Australia
    739
    Featured Threads:
    7
    1,805
    103
    Victor Harbor South Australia
    Ride:
    Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki
    After I have done bored throttle bodies, if this is any help, take the linkage off the stepper motor and set the idle with the screw. Match the idle set speed in your tune with tuneboy/tune ecu and remember what is was like in the old days. Just warm the engine for maybe 40-60 seconds until it will idle. ALL GOOD. No electrical genius needed. NO fault codes, no hair pulling etc etc. Good luck.
    BigNorm, Nat67, Claviger and 3 others like this.
  8. barbagris
    barbagris Mad Scientist
    10,092
    Featured Threads:
    55
    Media:
    85
    10,262
    823
    On the verge of insanity
    Ride:
    2009 R3-Standard - 1979 Guzzi V1000G5
    Nev - I can hardly remember what I had for breakfast. Oh wait -------------- Coffee.
    But sounds to me just like the "fitting different carb's" syndrome. Especially when you've not actually rebuilt them and inferred (usually incorrectly) the previous owner had.
    A tip for old Dellorto users - The Malossi transparent float bowls get porous and breathe as they age.
    BigNorm and Nat67 like this.
  9. Navigator
    Navigator Top Fuel
    Country:
    United States
    1,724
    Featured Threads:
    18
    2,523
    323
    Banner, WA
    Ride:
    2009 Rocket Touring
    OK, now it's all clear.
    TURBO200R4 likes this.
  10. Neville Lush
    Country:
    Australia
    739
    Featured Threads:
    7
    1,805
    103
    Ride:
    If it helps, remember a throttle body has absolutely nothing to do with fuelling. The ECU controls fuel via injectors. Throttle body is an AIR valve.
    Paul Bryant, Nat67 and TURBO200R4 like this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
