Joesmoe
IMOKUR2
Which are the connectors for the ignition switch and alarm, respectively, please ?
I have the service manual, and going to install DeCosse' keyless ignition, and the instructions couldn't be simpler, to wit:
1) Identify and disconnect the alarm bypass; connect the extension from the kit
2) Disconnect the ignition switch; connect the controller from the kit
Okay, there are a few other details, but that essentially is it.
I'm already not pleased with the Triumph manual for not cross referencing their information internally, with arrows and/or legends on their exploded diagrams for subsequent reference in the detailed instructions. So one is often playing, "Guess where this is" -- example: The manual shows the flasher and starter relays paired on the right side for the Standard, Classic, and Roadster; then the drawing under that says "Touring" and shows a single unit labeled "Flasher" -- o.k. -- where'd the starter relay go on the Touring ? Nothing.
Thanks in advance.
