MiniSuperDuke
.040 Over
Swapping out from chrome to black headlamp buckets. The chrome have original bulbs. The black have led's.
Can I just cut the zip tie at the grommet to then pull the wire harness through?
Im assuming the wires plugged into the connector will come out without cutting the wires? Must be clipped in somewhere. Maybe use a small screwdriver to release wherever its being held in place and pull.
The one with led's had the bulb taped up with masking tape. Never knew as it was like that when I got it but have never had a problem before. Led's worked as they should even though it looks like bulbs burnt out. When fitting led's should I tape it up like it was before? Or pull bulbs? Or something else?
Thanks for any input.
