Sump plate types and suitability?
Discussion in 'General Tech Talk' started by Ishrub, Feb 16, 2018.
Tags:
  1. Ishrub
    Ishrub Retired and loving it!
    4,968
    Featured Threads:
    63
    5,136
    823
    Ride:
    R3 Roadster,Sprint ST 1050 ABS, BMW R100RS sidecar
    I picked this up as a spare for Au$90 (US$70) today. The sump plugs alone must be worth that! ;):D
    I presumed being a late model and black it should be fine for my '10 model Roadster. Interestingly it was cast in 2008 a couple of years earlier than the product label which would suggest an early cutoff for R3 sumps that fit the Roadster.
    [​IMG][​IMG][​IMG][​IMG]
  2. leatal
    leatal Supercharged
    Country:
    United States
    474
    Featured Threads:
    9
    413
    73
    Dothan, Alabama
    Ride:
    2014 Roadster
    How come I never find steals like that? It retails for just short of $260! Good find.
    Ishrub likes this.
  3. warp9.9
    warp9.9 Pocałuj mnie w dupę
    7,894
    Featured Threads:
    9
    Media:
    14
    8,735
    823
    Forest City Illinois
    Ride:
    07 Rocket
    I'd be curious as to what the sticker on the bottom says.
  4. Ishrub
    4,968
    Featured Threads:
    63
    5,136
    823
    Ride:
    Took me a while but finally figured out you meant the previous label under the one in the 1st photo. ;):D
    It is upside down and appears very similar to the top one with a bar code in the middle and similar font text commencing underneath the barcode
    P/N: TXXXXXX
    SUMP M/C ASSEMBLY, BLK
  5. warp9.9
    7,894
    Featured Threads:
    9
    Media:
    14
    8,735
    823
    Ride:
    07 Rocket
    can you make the date out on it. you could be looking at a slight part number change in 2010 but the same part and was re labeled so it did not just sit on the shelf because every ordered the new part number. There has only been two sumps for the engine since 04. same with oil tanks early models were different but I believe it was just the fitting sizes of the supply and return.
    Ishrub likes this.
  6. Ishrub
    4,968
    Featured Threads:
    63
    5,136
    823
    Ride:
    Thanks for the clarification re changes to oil tank and sump.:thumbsup:
    T1230135 on the top label with Nov 2010 date is the same number as cast in with the 2008 date. Maybe the first sticker was just upside down so re-stickered.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
