DJ
Bob Ewell fell on his Knife.
My 2007 Classic has always pulled to the left. (I did buy it used. No idea of previous life)
last set of tires showed considerable more wear on the right side of the back tire. Might have been caused by low tire pressure. The front tire was fine.
I have always had to keep a slight amount of forward pressure on the right hand-grip to track straight.
I had a local Triumph dealership check the shocks, replace the oil, check the head-stock rear shocks etc. All were found (0r so they say) to be fine.
I've since loosened the motor mounts and re-torqued them to factory spec.
The left hand pull is much better since I re-torqued the motor mounts, but it still pulls slightly left.
I have taken the triumph summer screen off. No difference.
Any ideas?
Thanks,
D-
Any ideas?
Thanks,
D-
