JRCollings
.040 Over
Good afternoon Captains... I have a question, but first a bit of background to frame it for you.
I rarely used my rear brake other than when doing tight slow speed turns, coasting to a light hoping it will change, or holding me still on a hill... I had been under the impression (from hearing a 'rubbing' kind of noise coming from the rear on occasion), that my rear brake was NOT fully disengaging when lightly applied and then let off... I DID have this checked at the 600mile service and they said it was fine. However...
Today, went out with the boys for a breakfast ride, coasted down to a rolling stop at a set of lights, feathering rear brake and then took off to a cruise at about 75 for 8-10 miles... pulled up at traffic lights and thought I got a whiff of 'burning brake pad'. Upon riding off from light, tried depressing brake pedal - a LOT of travel and NO braking effect... got to Iowa Cafe, and looked... disc is 'blued' with heat and has a kind of 'deposit' on it in places, pads are toast....
I haven't really looked yet, so I apologize in advance, but I assume these are probably 'floating calipers'?
Either way, anyone know what caused this (and no, I did NOT have my foot resting on the brake pedal, I have my highway pegs set in a position where my foot can't touch the brake and I was using those, I also have it adjusted so it does not come on without a very deliberate downward tilt of the boot when on the normal pegs).... so assuming NO operator involvement - what caused this and how do I stop it happening again?
I had noticed on previous occasions that a 'sharp application and release' seemed to stop the noise / stop the binding, if I thought it was going on; so i am assuming some kind of sticky caliper or suchlike; but your opinions and experience greatly appreciated as this clearly needs to be fixed.
Thanks, John.
Thanks, John.
