Goliath, Let us know what you come up with and how well it works, I've thought about mounted speakers myself.
Currently I use earbuds with my I-Pod, my helmet is probably like the one described, you will usually find them under a sign that says "Novelty"? the earbuds work fine, the ones I use are Koss. http://www.amazon.com/Koss-The-Plug-Por ... B00001P4XA
But every time you get ready to leave you have to put them in and then you can't talk again till you pull them out and with the gauntlets on that is a pain.
HANDLEBAR SPEAKERS CHROME
HG Mounted Speaker Set with Amp
Weatherproof speakers with 2x15W output, which is controlled by a compact amplifier (LxWxH:75x52x25mm)
2 speakers including cable and connector, 1 amplifier, 1 connecting cable between personal stereo and amp, 1 live wire between amp and battery, 1 amplifier bracket with handlebar clamp.
Art.-Nr.: 37171000020 Price: £45,99
I know someone who runs them on a rocket and they are the dogs bollox
went to http://www.motorcyclespeakers.net/ and got the 150 watt low profile speakers. Mounted the amplifier under the left side cover. fits perfectly. Did not need the noise filter. When I ordered, they sent an extra mount which i used with some modification to mount the IPOD on the windshield bolt. Comes with a switch to control the volume that I mounted on the left handlebar. works great with gloves on. Also lets me power the volume down when you get to lower speeds. Crystal clear up to 60 MPH. 30 degrees hear today and so it was a short ride. I spoke to the sales rep and she said the waterproof speakers are good but you get what you pay for. these are water resistant but come with covers. Shopped around a lot and these were the best priced and the quality is excellent.
