Stepper Motor Pooched?
Zonechamp
Saskatchewan, Canada
2009 Rocket 3 Standard
My stepper motor does not move at all during startup. I reset all the perimeters and everything seems to be in spec. My question is, should I be able to move the shaft by hand at all? I can't budge it. Also is there a way to jumper it to make it activate so I can see if it moves or if it's seized?
i would pull the rubber back and spray it good with wd40.
info when u turn on key it should go out and then come back.
i would say to check the wires to see if u have volts at the time u turn the key on
i would not try to power the the stepper motor.
i do not know where the connector is but if u unplug the connector then u could check for ohms. if it has an open then it is bad.
if someone knows the ohms then u could use something similar like a light to plug in to check the circuit.
Not really, stepper motors need a driver that supply power to the different windings to hold position and to move in small steps. Simply supply power to the windings will not make it rotate.
Stepper motor - Wikipedia
Rick
It powers, but it doesn't move at all, at any time. That's why I was trying to figure out if it was the stepper or the TPS and associated wiring that makes it move. I really think it's the stepper as the TPS is set correctly. Thanks for the info.
No you should not be able to move it without a lot of force. Have you run the stepper motor test with tune ecu?
Everything was set up and tested a few months ago when I changed my primary TPS. I don't have a laptop right now so I tried to check it with my Android, and everything checks out.
well i played with my stepper motor (jokes ok)
there are 4 terminals and if u check them diagonally the ohms are 9 ohms each.
also just for fun i turned the ign on the stepper came out and then i unplugged it and started it a few times seemed to work good. if turned on the check engine light and then went off after a couple of starts after i plugged it back in.
the stepper motor is controlled by ecu the tps sends its signal to ecu.
this is just a guess i have never tried this if the ecu does not receive a tps signal it might not work the stepper motor.
can u tell if the tps is working with your android?
just thinking if your tps is reading and your stepper motor not working i would think that u could put some type of wedge or something between the motor and the throttle to make the tps read the .72volts then that should work till u get this corrected.
u might want to try taking the stepper off moving the rubber aside and spray it good with wd40 then just cycle the key a few times.
