Starter button blows fuses
When I hit the starter button the 5 amp fuse blows. To trace the fault I have done the following.
Check the starter button to make sure that it is not shorting to the handle bars. It wasn't, but I put some electrical tape over the wiring and on the bar just to be sure to be sure.
Remove the starter motor - no fuse blowing.
Put the starter motor back on, but not connect the high tension lead, and also disconnect the high tension lead from the solenoid to the motor. Fuse blows.
Remove the solenoid plunger and its cover plate. Fuse blows.
I think, therefore, that the problem must be in the solenoid mechanism, but I couldn't find anything that it shorting out.
Any ideas? Anybody in the area have a spare starter motor that I can borrow or buy?
