ozrider
2008 Standard
Like alot of others thanks to Speedy & BuffaloR3 I printed out the picture and instructions for the ignition switch bypass and had in my kit.
I was sorting and cleaning my kit out the other day and came across it...... good thing I had it in there but I didn't even have any wire to perform the bypass !!!!!
For about $20 I put together a plug and play bypass with a on/off toggle switch that can hang out under the seat, if i ever have the need for it......... as they say, "if you have it you won't need it"
For the Aussie guys I went to JayCar as I had come across a piggy back dual fuse holder and single fuse with a fly wire.
Part numbers are
fuse holder is SF-5125
!0 amp wire tap SF-5120
20 Amp wire tap SF-5124
Here is the link for the specs etc.
http://www.jaycar.com.au/productView.asp?ID=SF5122
http://www.jaycar.com.au/productView.asp?ID=SF5125&form=CAT2&SUBCATID=969#1
Part numbers are
