Brian Bracken
Brakster
my speedo stopped for no reason , checks made were
checked engine codes had 1501 error speed sensor
1 located sensor and disconnected 3 pin plug just on lhs of air box
2 check voltage on black/yellow lead should be 12 volts i had zero
3 main plug from instrument panel under tank 12volts going in on black / yellow no voltage on other side
4 pins in plug looked ok but cleaned with crc anyway and all ok fault disappeared
5 connect tune ECU and reset engine code
