Super D. Supercharged Joined Nov 27, 2007 Messages 288 Location So. Cal Ride 2005 Rocket 3 Standard Black, Flyscreen Aug 18, 2009 #1 Has anyone figured out how to take the speed limiter off of Tuneboy for the R3T? Or does anyone know if Wayne has plans on doing it?
Pig9r Living Legend Joined Mar 5, 2006 Messages 4,843 Location Kansas City, MO USA Aug 18, 2009 #2 No and no. Wayne from Tuneboy has said that he was asked by Triumph not to remove the limiter. However, member Head, has found that you can swap ECUs from standard to touring model.
GPMAZ Moderator Staff member Joined Feb 28, 2008 Messages 3,908 Location Arizona Aug 18, 2009 #3 I have raised the speed limiter on my R3T from 120 to 130 with Tuneboy. Wayne was unable to get to 6500 RPMs on the dyno with the limiter set to 120 so he raised it to 130 which is within spec for the rear tire.
dougl Living Legend Joined Sep 11, 2005 Messages 3,063 Location Reno, NV Ride 2007 R3 Classic Aug 19, 2009 #4 Pig9r said: No and no. Wayne from Tuneboy has said that he was asked by Triumph not to remove the limiter. However, member Head, has found that you can swap ECUs from standard to touring model. Click to expand... How much does an ECU cost? And is the standard ECU completely compatible with the R3T?
