Ok captains here is a more suitable solution for the plug wires then going with the expensive factory wires
($200) or a set that has been used.
Power Tripp performance sells an aftermarket set by Magnacore for roughly $94.00 + shipping.
The wires they have had made from Magnacor use the 7.5mm spiral wound wire with a long boot. It is a tight fit, but they do fit and seal well. You will need to unscrew the wire connectors from the stock coils and remove the connector and plastic seal inside. These will go on the Magnacor wires easily.
