Sorted 'out of range key fob' fault.
Telg1
Standard Bore
TN25 4EB
Rocket 3 GT
Every time i put the key next to the transponder the bike would start, but sitting on the bike it would not some of the time. I took the battery out and made the angle on the 3 bottom contacts to around 100 degrees and the same with the side contacts. AS the battery went back in it seemed to have a better contact and less movement. Since then the bike has had no issues. So i think it was just a case of poor contact with the battery.
I solved this problem just using the small key every time 😁
My personal theory is that it pops up the error message regardless of garlic, silver bullets or where you put your key.. :)
I haven't found a pattern anyway, seems totally random. That said it hasn't happened to me in a good while now (haven't changed anything including where i put it while riding)
