matty
- Joined
- Mar 10, 2010
- Messages
- 16
Okay fellas, here goes a long post.
Firstly, I am not mechanically minded and I have never used Tuneboy. As such, some of the post may not be in the correct terminology or I may not explain it properly. I didn't even know bikes had butterflies in them. Don't bother arguing or criticising with me or about Tuneboy or what I'm doing with my bike because I don't really care.
For those that don't know Wayne, the guy who invented Tuneboy, is in possession of my Roadster at the moment doing his thing. I had never met the bloke prior to handing the bike over and had spoken over the phone to him once. All I know is that he has a massive passion for allowing the rider to experience their machine more than they do now.
I spoke with him today and he gave me some numbers that he had found out. I joted all this info down while on the phone.
Re the Roadster, it would seem Triumph have appeared to give with one hand and take with the other.
For example-:
Wayne states that the Roadster appears to have a lot more grunt than previous models but it appears Triumph have given me more power but are limiting when I can use it. The numbers will show this later in the post.
The speed limiter is set at 194km/hr as opposed to the Standard at 218, the Classic at 193 and the Touring at 184.
The claimed higher rev limit of 6500K is actually 6300K, the same as the previous model I think.
Wayne already has 4 different mapping versions from his sources for the Roadster. Interestingly he says the secondary throttles (Not sure if thats the correct terminology) back off earlier in the French and German versions.
He was also surprised at the claimed HP and Torque readings as stated in the mags based on the initial map download, without having the bike on the dyno yet. He suspects the claimed HP was achieved in 3rd gear and the Torque in 4th or 5th.
His initial downloads show that in the Roadster in 1st gear that at-:
2.5K rev/min the secondary butterflies are open only 24%
at 3.5K open 32%
at 4K 37%
at 4.5K 58%
at 5K 90%
at 5.2K 100%
2nd Gear-:
Same as 1st
3rd Gear-:
at 2.5K open 24%
3.5K 31%
4.5K 48% (10% less than the same revs in 1st and 2nd gear)
5K 64%
5.2K 100%
4th and 5th gear shocked Wayne at initially the butterflies were open up to about 4.5K at 100% then back off!
4th gear
up to 4.5K open 100%
4.8K drops to 80% open
5K drops to 58%
5.2K drops to 47%
5.5K drops to 33%
6K stays at 33%
5th gear
up to 4.6K open 100%
at 4.8K open 87%
at 5K open 64%
at 5.2K open 35%
stays at 35% from then on.
So it appears in gears 1-3 you have to be riding at 5K revs to be experiencing any of the claimed power of the Roadster and in 4th and 5th gears it drops off if you continue to accelerate. Realistically when do we ride along at 5K revs plus. Never, except for a few short moments.
Thats the info I got off Wayne over the phone after the initial map download off the bike. He was about to do a dyno run with the normal set up then chuck on the filters, do his tuning and will do the other runs tonight.
Interestingly he thought the standard model had more punch off the mark than the Roadster. I can't comment having never ridden other R3's but when you look at how much the power is restricted in 1 - 3rd gears its not surprising. Anyhow, the numbers won't lie tomorrow.
So, it appears the Roadster is a weapon, but a highly restricted weapon.
So, fellow captains, there is the info I am able to share so far, and after 3glasses of a good red I'll shortly be sharing the love.
Further info on the .com site from tomorrow.
For example-:
at 3.5K open 32%
at 4K 37%
at 4.5K 58%
at 5K 90%
at 5.2K 100%
2nd Gear-:
Same as 1st
3rd Gear-:
at 2.5K open 24%
3.5K 31%
5K 64%
5.2K 100%
4th gear
5K drops to 58%
5.2K drops to 47%
5.5K drops to 33%
6K stays at 33%
5th gear
at 4.8K open 87%
at 5K open 64%
at 5.2K open 35%
