Joesmoe
IMOKUR2
DEcosse KeyLess Ignition System - Relay Kit Version
For Plug n Play Installation
Link Removed
Kit includes all per original supplied equipment
KeyLess Controller
RFID Antenna
Power Relay Harness
Alarm Extender harness
TWO RFID Remotes
Link to Original Installation guide included.
Harness lengths are suitable for the controller to fit behind the battery and the relay modules behind right panel; or both can go in the airbox if a RamAIR system has made this space available.
Kit will be suitable as-is for any R3 with the later-style (Gray) Sealed Key-Switch connector - will also be good for a Std/Classic with the older style (Black) unsealed connector with the addition of an adapter harness (or by swapping the connector for the older style). If required, DEcosse has confirmed you can purchase this adapter from him, or make your own.
Has been trouble-free (except when *I* forgot to replace the battery in the remote - the only maintenance item).
Asking $225.00
Link Removed
KeyLess Controller
RFID Antenna
Power Relay Harness
TWO RFID Remotes
Asking $225.00
