Kendan
.040 Over
Hey all. Seemed to run into a bit of an issue here. I purchased a couple of LED signal light bulbs for the rear signal lights (BAU15s), with the intent of using them with a Brake Module which is not installed. (running light, brake light, signal light). I just got the bulbs today, so just wanted to test them first, just to make sure they work. I popped out the stock signal light bulb, and put in the LED. Tried it out, and it worked fine. Even blinked at the correct speed, not the fast blink like I was expecting with an LED. Unfortunately the bulb would not fit with the clear lens cover on so I removed it, put the original bulb back in, and now the rear bulb doesn't work. The front signal light blinks fast tho. The other side, (right side) works fine, front and rear. I tried it a few times, removing the rear bulb, putting it back in, and no go. Rear signal light doesn't work, front one blinks fast. I then tried putting the LED bulb back into the rear socket, and same thing. Doesn't work, and the front one blinks fast.
Sort of at a loss here at the moment. It was getting dark, so I have to leave it till tomorrow anyways.
Anyone able to point me in the right direction? I checked the manual, thought maybe a fuse, but no reference to a signal light fuse. Did I somehow fry something by putting in the LED? It worked fine. Tried it a few times, as I was impressed by its light output.
Thanks all.
Thanks all.
