Jeremy .060 Over Joined Mar 4, 2018 Messages 195 Location Sioux City, IA Ride 2009 Triumph Rocket 3 Touring Mar 27, 2019 #1 What is this piece on the shift linkage? It seems like foam, but maybe its rotted rubber? Where can one get these and do they need to be there? Last edited by a moderator: Mar 28, 2019
1K9 No'mo Rocket 4 me Joined May 24, 2016 Messages 4,200 Location Clear Lake / Houston, Texas Ride Honda CB1100 Mar 27, 2019 #2 Jeremy said: What is this piece on the shift linkage? It seems like foam, but maybe its rotted rubber? Where can one get these and do they need to be there? Click to expand... Remove, clean, reassemble and ride.
Tal Living Legend Joined Dec 20, 2015 Messages 5,725 Location Christchurch, New Zealand Ride 2021 Triumph Rocket 3 GT Mar 28, 2019 #3 Google 'World of Triumph'....parts...Rocket 3...and search in there.You may just get what you need from them.
barbagris Mad Scientist Joined Aug 1, 2010 Messages 12,988 Location On the verge of insanity Ride 1979 Guzzi V1000G5 - 2018 KTM 790 Duke Mar 28, 2019 #4 It's a simple anti rattle thingie. Nylon washers. But from the reddish colour the link joint is toast. So make a new link with good rose joints and a bit of threaded bar. Shifting will get better.
R3T-Too Supercharged Joined Oct 27, 2014 Messages 449 Location Fort Worth, Texas Ride 2011 Rocket III Touring Mar 28, 2019 #5 I used a rubber boot made for the FJR to keep the grease in and the grit out; $10 for a pair. http://www.rpmracingca.com/proddetail.asp?prod=2H9-18154-00Set&cat=55 See a photo here. linkage boot
Jeremy .060 Over Joined Mar 4, 2018 Messages 195 Location Sioux City, IA Ride 2009 Triumph Rocket 3 Touring Mar 28, 2019 #6 R3T-Too said: I used a rubber boot made for the FJR to keep the grease in and the grit out; $10 for a pair. http://www.rpmracingca.com/proddetail.asp?prod=2H9-18154-00Set&cat=55 See a photo here. linkage boot Click to expand... Thank you, i have placed them on order. Much appreciated. what did you use to grease them before putting the boots on? how did you do it?
warp9.9 Pocałuj mnie w dupę Joined Jun 10, 2007 Messages 11,406 Location Forest City Illinois Ride 07 Rocket Mar 28, 2019 #7 R3T-Too said: I used a rubber boot made for the FJR to keep the grease in and the grit out; $10 for a pair. http://www.rpmracingca.com/proddetail.asp?prod=2H9-18154-00Set&cat=55 See a photo here. linkage boot Click to expand... Nice
R3T-Too Supercharged Joined Oct 27, 2014 Messages 449 Location Fort Worth, Texas Ride 2011 Rocket III Touring Mar 28, 2019 #8 Jeremy said: Thank you, i have placed them on order. Much appreciated. what did you use to grease them before putting the boots on? how did you do it? Click to expand... I used WD40 to clean em out. Then worked in some lithium grease.
