Installation
1. Lubricate the sensor O-ring with a smear of
petroleum jelly.
2. Manually push the second throttle to the fully open
position.
3. With the second throttle still held in the fully open
position, insert the sensor to the throttle body at the
angle shown below then turn it clockwise until the
screw hole aligns with the thread in the throttle body.
1. Sensor insertion position (dotted line>
2. Sensor initial fitted position <Solid line>
4. Insert the Torx screw but do not fully tighten yet.
5. Release the second throttle.
6. Refit the throttle bodies (see page 1/-190).
Z Temporarily reconnect the battery, positive (red) lead
first.
8. Turn the ignition to the ON position, which will close
Note:
• To ensure the second throttle is totally closed,
manually press the butterfly
have an assistant
closed.
9. Connect the diagnostic tool and scroll through to the
CHECK/ADJUST menu, select CHECK then select
the 'READ SENSORS' followed by the VOLTAGES
and SENSORS option.
10. Scroll through the data until the second throttle
position sensor voltage is displayed.
E
R D 5 E N 5 D R 5
R
[R
[ U
L
L D D D%
R T E L R D
D
2N T H R T L E D. 5 8
JJ
D D%
2N T H R T L E
11. Gently rotate the new throttle position sensor until
the voltage reading on the tool shows 0.6 volts +/-
0.02 volts.
12. Tighten the sensor retaining screw to 3.5 Nm and
voltage reading shown on the tool.
recheck the
Repeat the adjustment if the reading is outside the
specified range.
13. Disconnect the diagnostic tool.
14. Disconnect the battery, negative (blackllead first.
15. Check that the throttle opens and closes without
obstruction/sticking and has a smooth action
throughout the full range of its movement. Rectify
as necessary.
