bebsy
Finicky
Hi anybody come across this before, set up on diagnostic page 72% perfect until I installed the ram Air checked again it had jumped to 74% the boot was split and when I checked by touching the wires it fluctuated back and forth, anyhow I installed a new one and knock me down the problem is we're the jack plug off the tps fits into the loom if I set it to 72% it's fine but if I gently lift the jack plug we're it fits into the harness slightly it's fluctuating a couple of % either way? It runs fine although the tickover is a little low and the dreaded decal pop is back? Can't understand how that has happened I've not touched the map settings since I installed a custom map off Mr Hans, any help appreciated.
