Welcome, Joseph. Glad to have you on the board. The cold start issues have been discussed at length. Mine also has that problem. There are a number of solutions to the issue and it is just a matter of which way you want to go.
Before getting to the options, there is one task that you must do prior to doing anything. The headlights and starter circuit are combined and routed through the ignition switch. Downstream of the switch the circuit is split using a relay (referred to as the starter relay). When you hit the starter button, the headlights go out and the starter is engaged. When you let off the starter button, the relay switches the circuit back to the headlights. It is a myth and a waste of money to get any sort of kit that "turns off the headlights until you start". The real issue here is the circuit running through the ignition switch. The combined load of the twin headlights will end up melting the solder joints in the switch and cause the switch to fail. The solution is to fit a headlight relay kit. You can build your own or as most of us have done purchase the Eastern Beaver kit (
www.easternbeaver.com). This is really necessary as it is not a matter of if but when the ignition switch will fail.
Now for the cold start issue and possible solutions:
1. Tie a 2nd battery in parallel. This will require that you have made the intake mods so that you can drop a battery in the old airbox. Personally, I don't like this solution as it doesn't really resolve the source of the problem.
2. Replace the negative side battery cable. This is an easy job to make up a larger gauge cable and it make a big difference. Search for the thread on doing this mod.
3. Fit a secondary starter relay. Remember the discussion above, the primary starter relay switches the load from the headlights to the starter and back again. The headlight relay kit addresses the load when in normal operation, however, the entire load of the starter circuit is still routed through the ignition switch. The secondary starter relay mod is similar to the headlight relay kit in that the load is redirected to a direct line to the battery. This means that the full energy of the battery is delivered to the battery rather than being consumed in line loss.
4. Fit a higher powered starter motor. The stock starter is a 1.2 kW unit. You can get a 1.4 kW replacement from the local auto parts store. It is a 15 min effort to switch the motors out. The result is a faster spin of the motor.
I would strongly recommend that you do options 2 and 3 above together followed by option 4 and finally option 1.
There are threads on this site for each of the options.
