Dennsell
Top Fuel
- Joined
- Jul 5, 2009
- Messages
- 1,860
- Location
- Kawasaki Japan (Perth WA) (GY - UK)
- Ride
- Bonnie T 100, unfortunately not Rocket lll Country
Easy..
Fitted the Sebel Nautilus Horn (ebay $37.05) into the empty Air Box today, removed the Stock embarrasment completely and Tossed it
Then used the same cables just extended them. Connected them to the relay low voltage side. +84 and -85 (relay coil)
Tapped into the EB headlamp fused battery + supply cable after the fuse, ran the cable to the High voltage side of the relay 30 Battery Pos + (relay contacts), then other side of relay 87 to the horn pos +.
Ran a cable from horn negative - to the frame ground near the ECU.
Ignition on .. Press the horn button..WOW... Now I am Deaf in one Ear
