My next bike lift trick to try is going to be this: Lift the bike, start it in gear and hold a steel wool pad soaked with aluminum polish against the rear wheel to polish the tarnished aluminum that will devlope over time. Does this work? It seems like it should. Just don't remove a hand in the process. I have done a lot of dumb ass things in my life, maybe this is the next one.
Steel wool only for '06 wheels and newer. The previous years are clear coated.
BTW I just changed my oil and found that it drained a lot quicker if I kept the engine running. I would assume a coolant change would work the same way.
I have to tell you guys I do have a Sears bike lift but I never use it anymore and it's for sale. All joking aside.
I installed an overhead hoist in the shop with a steel beam that runs the length of the shop and an IR one ton air operated hoist on a trolley. I put it primarily for moving heavy objects from my big lathe and to help mount the chucks, but it makes a nice bike lift too. I just use a nylon sling to lift the bike up to get underneath.
Opinions are welcome on this thread, but it must be your own. Do not attempt to legitimize your opinion via some other writing, law, teaching, similar event, or source of information.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register. By continuing to use this site, you are consenting to our use of cookies.
