blip
Hey Everyone,
I've got a buddy with a Rocket Classic to fix (2005 model) that is having an issue starting.
The starter motor runs fine, all the normal startup sounds seem normal (although I am not sure exactly what the fuel pump prime sounds like, but it sounds the same as when I start my working bike) however the bike won't start.
When you put Quick start spray on the fuel filter and pulse the throttlle repeatedly it will start but only stay that way for a few seconds unless you continuously pulse the throttle (by pulse I mean repeated full throlle then release over and over again quickly) but even then it only stays running for 15 seconds max.
Any ideas what might be causing this or what I should look at? Your help is super appreciated.
