wyorocket
Standard Bore
2008 rocket wont start, no spark no fuel injectors. Dealer charged $500 and they knew nothing. I have self diagnosed with schematic and maunal, checked most everything. Started turns motor over, fuel pump, lights kickstand, gear indicator, relays,etc. I checked cranksensor. I attached diagnostic software and have no codes presently. When the unit first would not start it showed error code for 2 coils. And they check ok. In checking out the schematic, terminals B08 & B09(grounds for the ECU)on the connector for the ECU show that they should be directly to ground without any devices in between. When checking for resistance I show no resistance to ground as it should be. But when I turn on the ignition switch, the resistance for both B08 and B09 have 370ohms of resistance. Does anyone have an explanation for this or know where these 2 black wires terminate at on the cycle? Or other things to check? TY
