ZoneIII
I'm a new Rocket III Touring owner and I'm new to this forum. Since I do all my own work on all my machines, I knew before I bought the bike about checking and adjusting the valves and the necessity of removing the cams if they need to have the shims changed out. I found mention of the special tool that reportedly eliminated the need to remove the cams when adjusting valve clearance but I didn't see any posts by anyone who had or used one so I contacted the source that was mentioned in threads. I got immediate responses and the tool will be available if anyone wants one. I can't say how well they work, of course. The maker is trying to find a video that shows how it works. Here is the info I received from the maker. He also let me know that the price can be lowered if several people order them. I'll be interested in buying one. (Picture of the tool is at end of this post.)
"Triumph Rocket III Valve Adjustment Tool
Purpose:
The Rocket III valve adjustment special tool is designed to sigificantly cut down the time it takes to perform major valve service on all Rocket III 2300cc engines. This tool was designed with the help of licensed, factory trained Triumph technicians with over 15 years experience in all aspects of European
motorcycle mechanics. The tool has been tested and performs perfectly, saving many hours of labor costs allowing higher profit margins for service departments and technicians alike. This tool will easily pay for itself after just two major valve service operations.
Function:
The special tool allows valve adjustment to be done quickly and easily without the need to remove the camshaft, chain tensioner, cam chain, and thus eliminating the need to adjust the timing. A competent mechanic can remove and replace a shim in less than 15 minutes per valve. The valve adjustment tool works by pushing and holding the spring/bucket down to allow removal of the shim using a pick and magnet without the time consuming procedure of removing and replacing the camshaft and associated components and the resulting timing adjustment which should only be carried out by experienced technicians with all the special tools necessary to remove and replace the crankshaft, components and perform timing adjustment. Operation of the tool is so simple that anyone with basic knowledge of valve service can perform the procedure without the need for advanced training or experience with the Rocket III 2300cc engine.
Includes:
we are now taking preorders in order to determine the demand and quantity to be produced. The first run will be limited and few will be leftover for stock. Prepayment is required. Delivery in 4-6 weeks, 2-3 day priority mail shipping is free for all preorders. Price of the valve adjustment tool is $249.95.
About us:
The tool is a joint effort conceived by a leading Triumph technician and Concentric Machine, Inc. a full service protyping machine shop with over 25 years of experience producing time saving special tools and procedures for the automotive and transportation industry. Past clients include Mercedes Benz, BMW and
Range Rover. The tool is being marketed by the internet department of www.pureperformancecycles.com
For more info:
If you have any questions or would like more information about the Rocket III valve adjustment tool, please contact mike@pureperformancecycles.com or call
(954)501-3163. Thank you.
Purpose:
Function:
Includes:
- Valve adjustment tool
- Detailed, illustrated instructions on using the tool
- Video demonstration explaining the use and benefits of the tool
- Technical support for questions regarding use of the tool
About us:
For more info:
