bigern2300
.060 Over
Hey Guys,
Well, the ole' Rocket is at it again giving me fits! I reciently installed the engine update kit after my output shaft bearing failed, at no cost to me except my labor and time, and now a couple of months later, the charging system has taked a dump. Tried changing out the voltage rectifyer, but no luck. I pulled the starter and made sure the charging rotor wasn't rubbing the stator wiring and everything looked good there. Worthless factory manual doesn't give any specs for checking the altenator assembly as far as output specs. I think the rockect systems are a 3 phase system, not sure though. I do get some charging voltage, (around 12.4V) but not what it should be. I even tried it with a different battery with no luck. All connections look good and are doped with Dielectic grease. What i need to know is the output specs on the stator. Thanks, Bigern
