scribbler2300
Standard Bore
Hi All
Anyone out there had a problem with their Roadster losing battery charge when not being used? Mine just had a headlight relay fitted as part of a Triumph recall and since then the battery has been losing voltage at a rate of about 0.2 volts every 30 hours (even with a new battery installed). The Triumph shop says they tested the relay and it is not enough power draw coming from the relay to flatten the battery so it won't start after a week of sitting unused, but that is what's happening and you can feel a slight bit of warmth coming from the relay when the bike is off, so it must be drawing some current
Cheers:cry:
Cheers:cry:
