R3 Standard Classic Roadster
Installing the TR3017 risers will significantly reduce neck, back, and shoulder strain by relocating your handlebars up one-inch and back two-inches. Machined from a solid block of billet aluminum and finished with a beautiful chrome finish, the TR3017 will complement the look of your Triumph Rocket III. The TR3017 kit contains all hardware needed and installation instructions for an easy installation. There is no need to change or lengthen any cables, hoses, or wiring as the TR3017 can be installed using these factory components. The TR3017 also uses the factory riser caps to secure your handlebars. The TR3017 risers will fit 2004-newer Triumph Rocket III models except the Touring models.
Installation Guide
● Moves handlebars up 1” & back 2” towards rider
● Retains factory cable, hoses, & wires
● Uses factory riser caps
● CNC machined from solid billet aluminum
● Chrome finish
SKU: TR3017
Weight: 2.25 lbs
Dimensions: 7 × 7 × 7 in
Price: US$199.95
