eem1911
I'm going to do an install of Rivco's tip over bars on my 08' R3 & the instructions state that the engine must be supported or lifted a small amount to take pressure off the front engine mount in order to remove the engine mount bolt. My question is, if I leave the R3 on it's side stand & jack the engine up the required amount, once the front engine mount bolt is out, will the alignment of the engine & frame shift causing the re-insertion of the bolt to be a problem?
Thanks!
Thanks!
