I have New Old Stock of both the original R3 Touring Longhaul Dual and the rider's Solo seats with the mount holes for the rider's backrest available.
A used Solo R3 Touring seat A9708162
Au$ 350 (approx US$240)
A new old stock Solo R3 Touring seat A9708162
Au$ 450 (approx US$310)
I do have one original factory backrest ADJUSTABLE RIDER BACKREST - LONGHAUL A9708158 now
but I am keeping it for my other seats as it came with a custom made mount for R3Roadster Solo seats too.
Factory Triumph rider's backrest A9708160 with custom made R3 Roadster Solo seat mount. Utopia do a similar bracket mount for their backrest but it still requires the pillion seat bracket to be fitted. The beauty of this one is you can use the same rider's backrest for your R3 Roadster Solo...
www.r3owners.net
Easy enough to make riders backrests to fit.
I made a few kits with steel posts and aftermarket backrests.
By using 2 sizes of square post you can fit one over the other and drill multiple holes in each with cross bolts to allow height adjustment. I looked at vacuum cleaner hose and/or fittings including chrome tubes as cosmetic covers if desired.
4 short bolts and nylock nuts can be used to fix in 4 holes provided. Best to use a long handled socket extension and fit bolts from top and nuts underneath. I have test fitted this and another non adjustable system I cobbled up.
Square mounting hole from top with plug removed. The plug is fixed with the 2x center bolts.
Mount from underneath seat.
The hinge stem is chrome steel with a heavy chromed tube welded to the top for the cross bolt. I have shortened the stem and it can be drilled and attached to the seat post.
QUOTE REPLY
Report Edit
