Rocket3Pilot
So before I started modifying anything at all to my bone stock 2013 Roadster, I opened the secondaries 100% after receiving the go ahead from those responders on this website. Thanks again!
To my surprise, after reading so much about this single, all powerful trick or tip, I could not honestly detect any difference at all? So, just to make sure, I reinstalled the stock tune or map and rode again. No Change?
I went back to the hanger, double checked that I was in fact changing the map each time and did it once more with the secondaries opened 100%. Again, no change.
So, I couldn't see any point and returned the map to stock.
I understand that it may actually help when other things are done to the tune besides just opening the secondaries and I will get that done when I start adding the I/E mods with their proper tune.
Just thought it was interesting to try, and gave me some initial practice with TuneECU changing, saving, and labeling new tunes.
BTW I almost had a stroke with the first load to the ECU. Everything looked perfect, green bar filled, dialog box confirmed success, push red start button..............NO SOUND, NOTHING, AYFKM!!!! I tried everything as my blood pressure rose. I had to leave and distract myself with lunch to try to calm down, and while I was sitting in my stew.............THE HEADLIGHT FUSE! Of course you idiot. Ran back to hanger, inserted fuse, bike started immediately and ran perfectly. Blood pressure returned to normal while I suited up and waited for the fan to come on so I could go for a test ride.
DON'T FORGET THE FUSE!
